I've a problem with all LV2 plugins in Audacity version 2.3.3 (also with 2.3.2 installed via ubuntu repository).
Before posting here I've Google searched a lot to find a possible solution. I've searched this forum too.
I've installed various LV2 plugins from ubuntu repository (e.g. abgate, dpf-plugins-lv2, lsp-plugins-lv2, ...). Obviously the audacity LV2 support is enabled.
Once i try to enable any plugin (via Plugin Manager) i get:
Can you suggest a solution?Effect or Command at (url)
(plugin name) failed to register:
Could not load the library
Thanks in advance for your support
Kind regards,
Checco
Description: Ubuntu 19.10
Release: 19.10
Codename: eoan
Audacity v2.3.3 installed via ppa:ubuntuhandbook1/audacity
(previously I had Audacity v2.3.2 from repository)
