getting "please select a time within a clip" error message while using punch and roll.
Please state:
Quell
Post by Quell » Sun Apr 12, 2020 10:43 pm
Linux unbuntu
2.3.3 audacity version.
Everything was working fine an hour ago or so, came back from lunch, now I'm getting "please select a time within a clip" error message when I try to punch and roll I'm not sure what's wrong, haven't changed what I am doing and didn't change any settings. Any advice would be greatly appreciated.
Re: getting "please select a time within a clip" error message while using punch and roll.
Post by steve » Sun Apr 12, 2020 11:18 pm
Click on the track at the point where you want the punch & roll recording to start (for punch & roll, it must be within an existing track waveform).
