Pinebook 64?
Please state:
leachm99
Operating System: GNU/Linux other
Pinebook 64?
Post by leachm99 » Thu Apr 09, 2020 8:11 pm
Hi,
Hoping someone can tell me if Audacity will work well on a Pinebook Pro 64? This is a Linux laptop available at https://www.pine64.org/ that as i understand has an ARM processor and runs Manjaro Linux by default. Anyone doing this and is it working well for you?
Thanks
Re: Pinebook 64?
Post by steve » Thu Apr 09, 2020 8:22 pm
ARM64 is not officially supported, though we have received a report from a Linux software developer that he was able to get it running on a "Surface Pro X".
The Surface Pro X provides Win32 compatibility through an x86 emulation layer.
The only thing he wasn't able to get working was WASAPI loopback.
