Audacity 2.2.1 Variable Latency Problem
Please state:
Please state:
Re: Audacity 2.2.1 Variable Latency Problem
Hi steve , the quality of sound is good and i don 't have cracks and pops , i also tried to record using the embedded audio sound card of my pc as playback device (while recording with the focusrite 2i2 but the problem is the same after a while if the tracks segment is longer than about 16 seconds start going out of time
What settings are you using in the "Device Toolbar"? (https://manual.audacityteam.org/man/device_toolbar.html)
