having trouble when trying to record on a new track
Please state:
DeclareX
Post by DeclareX » Wed Mar 25, 2020 3:59 pm
Ubuntu 19.10
Audacity 2.3.2
PPA
I'm having trouble when I try to start a recording on a secondaty track that I've just created. I have to press R a couple of times to start out the recording. When I press first time, it creates a vertical line and nothing else.
DeclareX
Re: having trouble when trying to record on a new track
Post by DeclareX » Wed Mar 25, 2020 4:24 pm
i solved it. just go Edit --> Preferences --> Recording - and uncheck the option "Play other tracks while recording (overdub)"
