Live connect/disconnect to a sound card
Please state:
beanshed
Operating System: Linux Mint
Post by beanshed » Mon Mar 02, 2020 10:22 pm
I am using Linux Mint 19.1 Cinammon; and Audacity 2.2.1; which was installed from my distribution's release.
I would like to transfer from my tape recorder.I read that I could input on the sound card,at the light blue port.
Can I connect/disconnect there safely, with the computer running?.
Re: Live connect/disconnect to a sound card
Post by steve » Tue Mar 03, 2020 1:27 am
If it is a small round hole (mini-jack connector), then yes you can plug/unplug while the computer is on. The tape recorder should not be playing when you plug in / unplug.
beanshed
Post by beanshed » Tue Mar 03, 2020 4:51 pm
Thank You
