Can't get 2.3.3 installed with snap to find help files
Please state:
bboyes
Post by bboyes » Sun Mar 01, 2020 8:22 pm
In installed with snap from the Ubuntu SW manager and it works great. Thanks for a useful program. Now I want local help files installed. Urk. No joy.
I've followed the instructions at https://manual.audacityteam.org/man/unz ... anual.html but neither location works.
The preferences:interface option doesn't give me a whole path for help files, just "local". Where is that exactly?
I tried sudo unzip ~/Downloads/audacity-manual-2.3.3.zip -d /usr/share/audacity/help/ which puts the manual in
/usr/share/audacity/help/manual with icon and index.html located there. Audacity still tells me the manual is not installed.
How can I figure this out?
Thanks
Re: Can't get 2.3.3 installed with snap to find help files
Post by steve » Sun Mar 01, 2020 8:49 pm
Snap packages are sandboxed (isolated from the outside world), so it's probably not possible to access the manual unless the manual has been built into the snap package.
