My laptop squeaks while using Audacity
Please state:
Tomoms
Operating System: GNU/Linux other
Post by Tomoms » Thu Feb 27, 2020 2:08 pm
Hello guys, I'm about to describe a problem that is really, really weird.
So basically, each time I use Audacity 2.3.3 on my laptop (running openSUSE tumbleweed, package installed from the official distro repository) and I open a file, whenever I click on the audio waveform to do anything, I can hear a squeaking noise coming from the under the keyboard. The noise doesn't come from the speakers, but directly from some hardware component. If I click and drag the mouse cursor on the waveform, the squeaking noise is prolonged, and goes away as soon as I release the mouse's left button. I recorded the noise and uploaded it here: http://www.ubaweb.it/appoggio/fischio.mp3
I've noticed that if the laptop is not connected to the AC charger, the squeaking noise is still there, but fades out quickly and is not prolonged until the end of the click&drag movement. The noise is not related to the CPU load of the pc, because when I build some heavy projects using my laptop, I cannot hear it.
Audacity is the only program in which I've been able to find such a "scientific" way to produce this noise.
Let me add a few details, just to make the situation even weirder:
- no noise is produced when using Audacity on Windows
- no noise is produced when using Audacity 2.2.1 on Ubuntu 18.04
- no noise is produced when using Audacity packaged through Flatpak on openSUSE Tumbleweed!
It seems a problem of this specific, rpm-packaged release of Audacity (2.3.3).
I don't know to whom I should report the issue (Audacity devs? openSUSE bugzilla?)
Thanks.
Trebor
Re: My laptop squeaks while using Audacity
Post by Trebor » Thu Feb 27, 2020 6:09 pm
fischio.flac
Sounds like nails-on-chalkboard => HDD
(778.99 KiB) Downloaded 32 times
Post by kozikowski » Thu Feb 27, 2020 8:09 pm
What he said. You should be doing a complete, comprehensive backup of all your work on that drive.
Picture what would happen if it stopped working very soon.
Tomoms
Post by Tomoms » Thu Feb 27, 2020 8:28 pm
Ah sorry guys, I forgot to mention the laptop has got an SSD! So the drive can't be the problem here
Post by steve » Thu Feb 27, 2020 9:02 pm
In detail, how did you do that?
Is there, absolutely definitely, without shadow of doubt, no sound coming out of the laptop speakers?
Trebor
Post by Trebor » Fri Feb 28, 2020 3:53 am
... I forgot to mention the laptop has got an SSD! So the drive can't be the problem here ...
There are laptops with HDD & SSD.
The only other moving (spinning) part is the optical-drive, (if it has one).
Tomoms
Post by Tomoms » Fri Feb 28, 2020 8:49 am
No, the laptop had an HDD, I disassembled it and replaced it with an SSD.
I've recorded the noise using my phone.
There's no sound coming from the speaker and I know it because the sound is the same, no matter if the system audio volume is set to 100% or 0%.
I hope this leaves no shadow of doubt.
Post by steve » Fri Feb 28, 2020 9:37 am
Not quite - that's about 99% there.
If you plug in headphones into the laptop and ensure that sound goes to the headphones and not to the speakers, that gets us 99.9% no shadow of doubt.
I'm being very picky about this because I know that mouse movement can cause electrical interference inside the computer, and it sounds similar to your recording, but electrical interference itself is absolutely silent. Electrical interference can only be heard if it passes through a transduce (a "loudspeaker") to convert it into sound. If electrical interference caused by mouse movement is the cause, then I'd expect the sound to come through the headphones if connected.
If, on the other hand, the sound continues to come from "under the keyboard" when headphones are plugged in, then I would suspect it could be coming from a fan, though I can't explain how that could possibly be related to mouse movement.
Tomoms
Post by Tomoms » Fri Feb 28, 2020 1:00 pm
I've plugged my headphones in and the noise still comes from the under the keyboard. It comes from the area where the battery, the cpu and the fan are placed (I've watched a laptop disassembly video to confirm this).
Post by steve » Fri Feb 28, 2020 1:28 pm
To be clear, does the sound NOT come out of the headphones?
Does the graphics card / chip have a fan?
