Quickie Question!
Hello Steve and all
Can I install 2.3.3 if I have Linux Mint 17.3 ?
Thanks Danke
R
Quickie! Can I install 2.3.3 with Linux Mint 17.3
Please state:
Please state:
Red_Carpet
- Operating System: Linux Mint
Re: Quickie! Can I install 2.3.3 with Linux Mint 17.3
You will probably be struggling, due to the age of Mint 17.3.
It should be possible to build Audacity 2.3.3 on Mint 18 or later.
Mint 19 and later have Audacity 2.2.1 (from the main Ubuntu repository).
Red_Carpet
Oh - that's a shame.
Thanks very much for your reply
Cheers
Cheers
