Close = Exit now?: I can't close only 1 window at a time anymore [SOLVED]
Please state:
Please state:
Re: Close = Exit now?: I can't close only 1 window at a time anymore
Given that both of you that have this problem are using OpenSuse Tumbleweed, and we have no reports of the problem on other systems, and we are unable to reproduce the problem (on other operating systems), I think you should report this issue to OpenSuse. https://en.opensuse.org/openSUSE:Submitting_bug_reports
bdeceulaer
- Operating System: GNU/Linux other
That stacktrace comes after
- start new audacity
- Ctrl-N (create new project)
- Ctrl-W (close this last project)
Disabling the KDE Window Grouping makes no difference.
Starting with default settings (i.e. removing ~/.audacity-data) doesn't make a difference.
I also quickly see the popup window shown in the screenshot from androclus, which shows the list of audacity plugins.
So I tried disabling all plugins and then restart audacity, Ctrl-N, Ctrl-W ... crash.
No idea if the following contains useful info. Starting audacity from console shows this in the console :
==> The last line shows only after the Ctrl-W
Code: Select all
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/Ambience>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/Bandisto>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/BeatBox>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/Combo>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/DX10>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/DeEss>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/Degrade>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/Delay>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/Detune>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/Dither>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/DubDelay>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/Dynamics>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/EPiano>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/Image>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/JX10>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/Leslie>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/Limiter>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/Loudness>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/MultiBand>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/Overdrive>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/Piano>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/RePsycho>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/RezFilter>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/RingMod>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/RoundPan>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/Shepard>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/Splitter>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/Stereo>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/SubSynth>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/TalkBox>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/TestTone>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/ThruZero>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/Tracker>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/Transient>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/VocInput>
lilv_world_add_plugin(): warning: Reloading plugin <http://drobilla.net/plugins/mda/Vocoder>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Analyzer>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/BassEnhancer>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/CompensationDelay>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Compressor>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Crusher>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Deesser>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Emphasis>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/EnvelopeFilter>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Equalizer12Band>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Equalizer30Band>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Equalizer5Band>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Equalizer8Band>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Exciter>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Filter>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Filterclavier>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Flanger>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Fluidsynth>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Gate>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/HaasEnhancer>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Limiter>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/MonoCompressor>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/MonoInput>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Monosynth>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/MultiChorus>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/MultiSpread>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/MultibandCompressor>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/MultibandEnhancer>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/MultibandGate>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/MultibandLimiter>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Organ>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Phaser>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Pitch>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Pulsator>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Reverb>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/ReverseDelay>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/RingModulator>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/RotarySpeaker>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Saturator>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/SidechainCompressor>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/SidechainGate>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/SidechainLimiter>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/StereoTools>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/TapeSimulator>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/TransientDesigner>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/VintageDelay>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Vinyl>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Vocoder>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/Wavetable>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/XOver2Band>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/XOver3Band>
lilv_world_add_plugin(): warning: Reloading plugin <http://calf.sourceforge.net/plugins/XOver4Band>
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.Audigy2.pcm.hdmi.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
ALSA lib conf.c:4677:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5165:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM hdmi
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.Audigy2.pcm.modem.0:CARD=0'
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline:CARD=0,DEV=0
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM phoneline
Expression 'alsa_snd_pcm_hw_params_set_buffer_size_near( pcm, hwParams, &alsaBufferFrames )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 923
ALSA lib pcm_oss.c:377:(_snd_pcm_oss_open) Unknown field port
ALSA lib pcm_usb_stream.c:486:(_snd_pcm_usb_stream_open) Invalid type for card
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Expression 'stream->playback.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 4611
Segmentation fault (core dumped)
Reason: code tags added
bdeceulaer
OpenSuse Tumbleweed, KDE ==> command "ksystemlog" opens a window which shows the kde system log
Then start audacity, Ctrl-W ==> the kde system log shows the crash stracktrace
It's actually not needed to first do Ctrl-N to create a new project. Just closing first audacity window with Ctrl-W causes the same crash, but you only notice it's a crash by looking into the system log.
Let me know if I can do anything to provide better info.
I've tested on Tumbleweed, and the problem is repeatable.
The problem does not occur on other Linux systems that I've tried (Debian (Gnome), Ubuntu (Xfce), Mint (Cinamon)), so it appears to be a Suse or KDE problem. As the Audacity version in Tumbleweed isn't a debug build, I'm not able to diagnose the problem further.
I'd suggest that you report the bug to OpenSuse. Please do keep us informed of any updates.
bdeceulaer
I filed a new bug on Bugzilla for OpenSuse :
https://bugzilla.opensuse.org/show_bug.cgi?id=1162418
I'll keep you informed when I get an answer there.
Thanks. Yes, please do.
FIXED
The problem with openSUSE:Tumbleweed was caused by the particular variant of wxWidgets being built with LTO (Link Time Optimization) this is why it was particular to Tumbleweed.
Re: Close = Exit now?: I can't close only 1 window at a time anymore [SOLVED]
Thanks for the update.
I'll close this topic so that the fix remains at the end of the thread, in case anyone else is searching for the solution.
