Audacity freezes at startup and its logo remains frozen in the screen
Please state:
Re: Audacity freezes at startup and its logo remains frozen in the screen
Post by steve » Tue Feb 25, 2020 6:00 pm
When you try to launch Audacity from a terminal window, what is the full terminal output?
oliverjames
Operating System: Linux Mint
Post by oliverjames » Tue Feb 25, 2020 7:49 pm
This is the full output:
$ audacity
(Audacity:4951): Gtk-WARNING **: 20:48:12.638: gtk_disable_setlocale() must be called before gtk_init()
Post by steve » Tue Feb 25, 2020 10:44 pm
Unfortunately that tells us very little. I had hoped that it had got further than that.
Am I right in thinking that the problem first appeared with Mint 19, and is still a problem with the latest 19.3 version?
oliverjames
Post by oliverjames » Wed Feb 26, 2020 7:50 am
Yes, that's correct. Audacity worked perfectly on Mint xfce 18.3.
Post by steve » Wed Feb 26, 2020 9:17 am
Do you know which Ubuntu versions they are based on?
oliverjames
Post by oliverjames » Wed Feb 26, 2020 9:23 am
Linux Mint 19 and 19.3 are based on Ubuntu 18.04. Linux Mint 18.3 is based on Ubuntu 16.04.
Post by steve » Wed Feb 26, 2020 9:55 am
Interesting, because Audacity does not have this problem in Ubuntu 16.04 or 18.04 (I've used both, extensively, with Xfce, and no reports from other Ubuntu users. I think this needs to be sorted out by Mint. This appears to be their bug tracker, but it looks like a Mint account is required https://bugs.launchpad.net/linuxmint Perhaps, as part of the Mint community, you could look into that.
Post by steve » Fri Feb 28, 2020 6:29 pm
Just a thought: Do you have both packages installed: "audacity" and "audacity-data"?
jg1
Post by jg1 » Sat Mar 07, 2020 12:30 pm
Hope this is not too far off topic to be of interest, but given previous posts about kernel versions, I've just done an out-of-the box re-install of Xubuntu 18.04 with kernel 4.15.0-88. Audacity 2.2.1 from the repo starts fine first time but if I close it and want to restart it, it hangs in exactly the way described here for Mint 19.2. I have Audacity on an exactly similar Dell XPS17 machine with kernel 4.15.0-20 and Audacity 2.2.1 works just fine. I also have Xubuntu on another m/c running kernel 4.4.0-174 and another running 5.3.0-40 and both work fine with Audacity 2.2.1. So to me it appears to be a kernel version issue rather than Mint-specific.
The machine running 4.15.0-88 is my preferred m/c for audio editing and up to now it's been AOK. It's due for a software upgrade but I was hoping to wait until 20.04LTS comes along, so I too am looking for a sensible work-around.
jg
oliverjames
Post by oliverjames » Mon Mar 09, 2020 11:10 am
Apologies for the delayed reply. Yes I have both packages installed. I tried long and hard to get Audacity to work on this machine running Mint xfce 19.3. I discovered that opening /var/tmp/audacity-richard/ and deleting the lock file would enable me to launch the programme. I tried re-locating the temp file in my home directory, no improvement.
I finally gave up and flashed back my Mint XFCE 19.1 image to find that audacity runs perfectly (kernel 4.15.0-88) Given that Audacity also runs perfectly under Mint xfce 19.3 on my old Asus EEEPC (same kernel) I'm at a loss as to the cause.
