Audacity can't find "libwx_gtk2u_xrc-3.1.so.1" on Oracle Linux
Please state:
FlatAssembler
Operating System: Linux Debian
Re: Audacity can't find "libwx_gtk2u_xrc-3.1.so.1" on Oracle Linux
Post by FlatAssembler » Mon Nov 04, 2019 4:04 am
Here is what I get if I type "sudo yum install pulseaudio":
Code: Select all
[sudo] password for teo.samarzija:
Failed to set locale, defaulting to C
Loaded plugins: langpacks, ulninfo
Package pulseaudio-10.0-5.el7.x86_64 already installed and latest version
Nothing to do
Post by steve » Mon Nov 04, 2019 9:43 am
That's curious. You have PulseAudio installed, but it's not available to Audacity.
Are you able to open Pulse Audio Volume Control from the command line (without using su or sudo)
Code: Select all
pavucontrol
FlatAssembler
Post by FlatAssembler » Mon Nov 04, 2019 1:53 pm
Code: Select all
pavucontrol
Code: Select all
bash: pavucontrol: command not found...
Post by steve » Mon Nov 04, 2019 1:56 pm
Try installing pavucontrol (it is recommended for audio work on Linux).
FlatAssembler
Post by FlatAssembler » Mon Nov 04, 2019 4:07 pm
OK, thanks, now that I've installed it, Audacity can record sound from my microphone.
Post by steve » Tue Nov 05, 2019 7:50 am
That's good.
Did you manage to get FFmpeg working?
FlatAssembler
Post by FlatAssembler » Tue Nov 05, 2019 9:37 am
That's good.
I'll try it when I find the time. I am studying electrical engineering and computer science at the FERIT University in Osijek and it's rather demanding.
Like I've said, I've compiled FFmpeg from source and it works when it's invoked directly. So, if I need it, I can use it directly, I don't need to do it through Audacity.
Post by steve » Wed Nov 06, 2019 7:39 pm
If you're not able to get Audacity to recognize FFmpeg, you would still be able to export using FFmpeg as an "external program": https://manual.audacityteam.org/man/exp ... ogram.html
