Excellent
When does that appear?
Which version of Audacity did you build?
Excellent
It appears when I click the "Record" button.
I built Audacity 2.3.2. Here is what I see when I click Help>About: One more problem. Audacity claims it can't find the "libavformat.so.55" file, even when I point it right to it.
Audacity is very fussy about the version of FFmpeg, because, by default, Audacity links to it dynamically.FlatAssembler wrote: ↑Sat Nov 02, 2019 8:14 pmOne more problem. Audacity claims it can't find the "libavformat.so.55" file, even when I point it right to it.
Code: Select all
../configure --with-lib-preference="local system" --with-ffmpeg="system" --disable-dynamic-loadingHere is the "deviceinfo.txt" file.
Code: Select all
(Audacity:18610): Gtk-WARNING **: 08:51:01.117: Locale not supported by C library.
Using the fallback 'C' locale.
(Audacity:18610): Gdk-WARNING **: 08:51:01.127: locale not supported by C library
(Audacity:18610): Gtk-WARNING **: 08:51:01.134: gtk_disable_setlocale() must be called before gtk_init()
ALSA lib pcm_dmix.c:1108:(snd_pcm_dmix_open) unable to open slave
ALSA lib pcm.c:2564:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2564:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2564:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm_route.c:869:(find_matching_chmap) Found no matching channel map
ALSA lib dlmisc.c:287:(snd1_dlobj_cache_get) Cannot open shared library /usr/lib/alsa-lib/libasound_module_pcm_pulse.so ((null): /usr/lib/alsa-lib/libasound_module_pcm_pulse.so: wrong ELF class: ELFCLASS32)
Expression 'stream->playback.pcm' failed in '../../../lib-src/portaudio-v19/src/hostapi/alsa/pa_linux_alsa.c', line: 4611
08:51:01: Debug: ScreenToClient cannot work when toplevel window is not shown
08:51:01: Debug: ClientToScreen cannot work when toplevel window is not shown
08:51:01: Debug: Unrecognized accel key 'backspace', accel string ignored.
08:51:01: Debug: Unrecognized accel key 'numpad_enter', accel string ignored.
Nothing to worry about there. Those messages are "normal".FlatAssembler wrote: ↑Sun Nov 03, 2019 7:52 amPerhaps related to that, if I start Audacity from command line, I get the following warnings:
That's interesting. According to the device info, you don't have any recording devices and you don't have PulseAudio.
Code: Select all
arecord -lOK, here is what I get if I type "arecord -l":steve wrote: ↑Sun Nov 03, 2019 12:40 pmNothing to worry about there. Those messages are "normal".FlatAssembler wrote: ↑Sun Nov 03, 2019 7:52 amPerhaps related to that, if I start Audacity from command line, I get the following warnings:
What do you get if you enter in a Terminal window:(last character is lower case "L")Code: Select all
arecord -l
Code: Select all
**** List of CAPTURE Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC255 Analog [ALC255 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0I don't even know what is PulseAudio. What I do know is that GNOME Cheese can record audio without problems.
