Automatic Focus on Track Has Not Worked Since 2.2.0
Please state:
sagetyrtle
Post by sagetyrtle » Tue Jul 23, 2019 10:40 am
OS: Linux Mint XFCE
Audacity: 2.2.1, distribution release
I have a track focus issue that appeared with 2.2.0.
I've been using Audacity since 2005. Up until 2.2.0, my workflow looked like this:
1. Open Audacity. Record. Stop recording.
2. Track is automatically focused, so I use keyboard shortcuts to work with the track.
When 2.2.0 came along, my workflow turned into this:
2. Now the track is NOT automatically focused. The focus goes to any toolbar I have open. Which means using the mouse to focus the track first, then I can use keyboard shortcuts to work with the track.
Current Work-Around:
So I've closed every single toolbar. Now the focus has to go to the track, because there's nowhere else for it to go. I do miss the Selection toolbar, though, and would like the ability to have it open AND have automatic track focus.
I know Audacity is capable of this, because up until 2.2.0, it worked perfectly. (I would love to downgrade to 2.1.3, but my system says it's too old now.)
Any ideas? Is there a better work-around that I've missed? Should this be a bug report?
Thanks so much for your time.
Re: Automatic Focus on Track Has Not Worked Since 2.2.0
Post by steve » Tue Jul 23, 2019 11:36 am
By coincidence, this bug is currently being discussed on the developer's mailing list.
I don't yet have a workaround to suggest, but hopefully, now that the developers are discussing the problem, a fix will be found soon.
sagetyrtle
Post by sagetyrtle » Tue Jul 23, 2019 12:17 pm
Great! I'm so pleased it's being looked at. Fingers crossed for a fix eventually.
