Linux version: Linux Mint 18.3
Audacity: 2.3.2, distribution release
My id14 records beautifully, but I'm not able to hear what I'm saying into the mic via the headphones. The headphone volume is at the correct level and I've selected headphone from the 3 possible choices.
Any ideas? Thanks so much for your suggestions.
can't hear headphones id14 Audient USB Interface
Please state:
Please state:
sagetyrtle
Re: can't hear headphones id14 Audient USB Interface
Plug your headphones into the id14.sagetyrtle wrote: ↑Tue Jul 09, 2019 5:14 pmMy id14 records beautifully, but I'm not able to hear what I'm saying into the mic via the headphones.
I couldn't find a user manual online, but first check your user manual to see if the interface has "zero-latency monitoring" or "direct hardware monitoring", or something like that. If you have that option you can monitor without going-through the computer. I don't see a switch for that, so if it exists would have to be enabled with a software utility.
I assume you can hear through the headphones when you play-back the recording (or play some existing file)?
Enable Software Playthrough Of Input to monitor what you're recording. You'll get latency (delay) through the computer so you may have to experiment with Latency/Buffer Length. (A bigger buffer creates more delay and if the buffer is too small you'll get glitches/dropouts in your recording.)
sagetyrtle
Steve - Right, I ought to have mentioned that my headphones are plugged into the id14.
DVDdoug - How odd, when I enabled "software playthrough of input", the record button stopped working. When I turned it back off, the record button worked again.
When I listen to the file with my headphones after it's been recorded, there are no problems. At that point my headphones are plugged into my USB speakers. Any ideas?
sagetyrtle
Re: can't hear headphones id14 Audient USB Interface [SOLVED]
Hooray! A person in the Linux Mint forums solved the issue.
* install alsamixer
* start from terminal
* scroll to the right
* turn headset volume up
All set.
* install alsamixer
All set.
