HDMI output?
Please state:
iraj
HDMI output?
Post by iraj » Sun Dec 30, 2018 6:33 am
Friends: I'm having the same trouble recording and playing through HDMI. I'm using Ubuntu 18.04.1 LTS, and Audacity 2.2.2. Here's the screenshot of the imported music played and paused, and the PAVU playback screen. I can't record from my HDMI connection. (I also don't know how to insert the screenshot image, so the link is to a dropbox file.) Thanks for any help.
iraj
Re: HDMI output?
Post by iraj » Sun Dec 30, 2018 6:38 am
Well, my image doesn't appear, so I'll need help on how to load that too. Sorry.
Iraj
Re: HDMI output?
Post by steve » Sun Dec 30, 2018 11:30 am
I've split this to a new topic as the original topic was solved (it was user error). The solution to the original topic was here: viewtopic.php?p=342906#p342906
If it really is "the same" trouble, then the answer is here: viewtopic.php?p=342906#p342906
I suspect that you have a different problem, so please describe in detail, what you are trying to do, what you are using, what you are doing, and what is happening.
See here: viewtopic.php?f=49&t=64936
