Arch Linux with audacity 2.2.2
Bug is well explained here https://github.com/awesomeWM/awesome/issues/2292 and https://github.com/awesomeWM/awesome/issues/2382
Can you please check, is it audacity problem or not.
BUG: Black rectangle instead of splash screen
Please state:
Please state:
Re: BUG: Black rectangle instead of splash screen
Doesn't happen for me on Xubuntu.
My guess is that it is specific the AwesomeWM. Have you tried with a different WM? Is Audacity OK on AwesomeWM other than the splash screen?
Yea. Audacity has no problem on other wm's. But, as I see, you are using wxwidgets to make splash screen. If I run wxwidgets' splash screen exaple it works correctly on awesome. Maybe you are doing somethink specific. It looks like race condition, as audacity shows splash screen in 40%. See more https://trac.wxwidgets.org/ticket/18216#comment:9
Which version of WxWidgets, built against which version of gtk?
I don't think Audacity 2.2.2 was tested with WxWidgets 3.0.4, though I wouldn't expect major problems. It's supposed to be built against Wx 3.0.2 (with gtk2 - gtk3 is known to cause major problems). The next version of Audacity should be built against Wx 3.1.1 and gtk2.
