Steinberg UR12 - Audacity 2.2.2 - Linux Mint
Please state:
horsebadorties
Post by horsebadorties » Sat Aug 25, 2018 12:16 am
Before I purchase a microphone to USB (A2D converter) preamp, do I need a special driver for Linux?
I previously used a Roland Duo-Capture that did not need a special driver.
Re: Steinberg UR12 - Audacity 2.2.2 - Linux Mint
Post by steve » Sat Aug 25, 2018 11:56 am
It depends on what the device is. If it is "class compliant USB", then it should work fine with Linux without installing any special drivers. For anything else, check the manufacturer's website and / or do an internet search to find information about compatibility.
horsebadorties
Post by horsebadorties » Sat Aug 25, 2018 10:18 pm
thanx again Steve.
