skip save project nag box
Please state:
Garthhh
Post by Garthhh » Thu Aug 16, 2018 9:26 pm
I'm trying to limit the number of times I have to switch from keyboard to mouse
Edit>Preferences>Warnings>Saving Projects box is unchecked
Audacity 2.1.3
Mageia 6
Re: skip save project nag box
Post by kozikowski » Thu Aug 16, 2018 9:49 pm
Unfortunately, Audacity isn't a WAV editor. It's a Project Manager, and it doesn't matter how many MP3s you create, if you didn't satisfy Project Hygiene, you're going to get the message.
Yes, it is annoying.
Post by kozikowski » Thu Aug 16, 2018 9:50 pm
Is this one of those times the Linux people have scrambled Audacity numbers? The current version is 2.2.2.
Post by steve » Thu Aug 16, 2018 10:39 pm
"Ctrl + Q" (Quit application)
"Alt + N" (No, don't save.)
waxcylinder
Post by waxcylinder » Fri Aug 17, 2018 2:56 pm
Yes the "Yes" is the default in that message and that is intentional to encourage saving of projects so they don't lose their work.
You should be able to work it from the keyboard without the mouse - just use Tab to tab to the "No" button - then press Enter
Garthhh
Post by Garthhh » Tue Aug 21, 2018 5:50 am
Thanks for the replies
no ability to tab on many of the audacity screens, which also require triple clicks to use
ctrl +q, works to close audacity, I am only trying to close the file [which I changed to shift + a]
10 Years ago audacity to lp - mp3 for a couple 100 albums
I was on windows so used MP3directcut & named with Itunes
todays project is chop a few 100 files into twice as many [or more] smaller files
gotta good flow going with some keyboard short cuts
still have a bottle neck at: Export Selected Audio screen, it insists on a .aiff, file extension even though I'm exporting mp3
so move cursor, type mp3, delete aiff
Post by steve » Tue Aug 21, 2018 8:26 am
Neither of those are known bugs in the Audacity source code. Perhaps worth reporting them to the package maintainer.
