I installed audacity-freeworld from the rpmfusion repository version 2.2.2 and I cannot get sound either through normal headphones nor bluetooth headphones. I get the same problem if I install audacity from the fedora repositories (although their version is 2.1.3
VLC, Chrome, Mozilla, all of them can playback sound without problems.
But Audacity does not seem to find the device to playback sound.
If I go to preferences, It only gives me the HDA Nivida options
I can't see the HDA Intel device
How can I troubleshoot this? How can I get Audacity to playback sound through the headphones?
Here is the Device Info from the Help->Diagnostics->Audio Device Info
Code: Select all
Default recording device number: 0
Default playback device number: 1
Device ID: 0
Device name: HDA Intel PCH: ALC887-VD Alt Analog (hw:0,2)
Host name: ALSA
Recording channels: 2
Playback channels: 0
Low Recording Latency: 0.005805
Low Playback Latency: -1.000000
High Recording Latency: 0.034830
High Playback Latency: -1.000000
Supported Rates:
Device ID: 1
Device name: HDA NVidia: HDMI 0 (hw:1,3)
Host name: ALSA
Recording channels: 0
Playback channels: 8
Low Recording Latency: -1.000000
Low Playback Latency: 0.005805
High Recording Latency: -1.000000
High Playback Latency: 0.034830
Supported Rates:
32000
44100
48000
88200
96000
176400
192000
Device ID: 2
Device name: HDA NVidia: HDMI 1 (hw:1,7)
Host name: ALSA
Supported Rates:
32000
44100
48000
88200
96000
176400
192000
Device ID: 3
Device name: HDA NVidia: HDMI 2 (hw:1,8)
Host name: ALSA
Supported Rates:
32000
44100
48000
88200
96000
176400
192000
Selected recording device: 0 - HDA Intel PCH: ALC887-VD Alt Analog (hw:0,2)
Selected playback device: 1 - HDA NVidia: HDMI 0 (hw:1,3)
Supported Rates:
44100
48000
96000
192000
Available mixers:
Available recording sources:
0 - Rear Mic:0
1 - Front Mic:0
2 - Line:0
3 - CD:0
4 - Rear Mic:1
5 - Front Mic:1
6 - Line:1
7 - CD:1
Available playback volumes:
0 - Master:0
1 - Headphone:0
2 - PCM:0
3 - Front:0
4 - Front Mic:0
5 - Front Mic Boost:0
6 - Surround:0
7 - Center:0
8 - LFE:0
9 - Line:0
10 - Line Boost:0
11 - CD:0
12 - Beep:0
13 - Rear Mic:0
14 - Rear Mic Boost:0
Recording volume is native
Playback volume is native
