How to use headers pse ?
Please state:
Evert2
Operating System: Linux Debian
Post by Evert2 » Mon Jul 16, 2018 8:15 pm
Hello everybody !
Me was told that one can use headers in Audacity, to play sound (music) from one header to the other.
But how does that work ?
Say I put some 20 headers in a file, and after that I make a list, how to play it.
For example Start1 > End1
Start1 > End1
(meaning play that part twice)
Start6 > End6
Start9 > End9
Start7 > End7
Well.... after that you play it to check everything, and if all is ok, you save everything in the same order.
How would that be possible with Audacity ?
This will never damage the original file.
Kind regards,
Evert
Re: How to use headers pse ?
Post by steve » Mon Jul 16, 2018 8:34 pm
I'm not sure what you mean, but perhaps this? https://manual.audacityteam.org/man/lof_files.html
