Please state:
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade (see
https://www.audacityteam.org/download/).
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
waxcylinder
Post
by waxcylinder » Mon Jul 16, 2018 2:50 pm
Note that embedded white space between audio clips is treated as (an made into) silence on Export - which means that if tou re-imported such an audio file you would see silences rather than white space.
And if we did treat white space before audio as silence the export, followed ny a later import would hav the leading white space changed to silence.
I assume that those behaviors are or would not be a problem
Peter.
waxcylinder
Post
by waxcylinder » Tue Jul 17, 2018 12:00 pm
Steve and I discussed this at length yesterday - an as a result of that I have logged this issue on our bugtracker:
https://bugzilla.audacityteam.org/show_bug.cgi?id=1904
We probably do not have time to address this for the upcoming 2.3.0 release - but hopefully we may be able to for the subsequent releases.
Peter.
Iarfhlaith
- Operating System: OS X 10.9 Mavericks
Post
by Iarfhlaith » Tue Jul 17, 2018 1:09 pm
That’s incredible, I really appreciate you putting it on the list. Any time is better than never.
waxcylinder
Post
by waxcylinder » Tue Jul 17, 2018 1:36 pm
Iarfhlaith wrote: ↑Tue Jul 17, 2018 1:09 pm
It's been bothering
(some of) us for a long while now - it's just that no-one had gotten around to putting in the thinking time required.
Hopefully we can get it sorted now that we have articulated the problem and a probable solution.
I did, as promised, update the Manual page for 2.3.0 to document current existing behavior and Steve's simple workaround - see:
https://alphamanual.audacityteam.org/ma ... nu:_Export
Peter
