Metadata Error: Unknown text information frame
Please state:
rlearning
Re: Metadata Error: Unknown text information frame
Post by rlearning » Fri Jul 13, 2018 11:16 am
I sent this link to myself on another machine and it seems to work. Let me know if you still have a problem and I will try something different.
https://www.dropbox.com/s/t6xvrchne9bkj ... y.mp3?dl=0
Post by steve » Fri Jul 13, 2018 11:57 am
OK, got it.
I can see the problem, but I'm unsure what is causing it or how to fix it. I'll need to investigate further.
Post by steve » Fri Jul 13, 2018 12:16 pm
It appears to be a bug in Audacity 2.2.2.
The good news is that it does not occur in the development code (Audacity 2.3.0 alpha).
Until Audacity 2.3.0 is available, I'd suggest that you use some other application for editing the metadata of MP3 files. There are several suitable applications available in the Ubuntu repository. "EasyTag" is pretty good, and it can fix these bad tags automatically.
rlearning
Post by rlearning » Fri Jul 13, 2018 12:57 pm
Like I mentioned early on, I have my Windows version which I can use until then.
Any idea as to when it will be released, or about when it supposed to be released?
Thanks for your help.
Post by steve » Fri Jul 13, 2018 1:21 pm
It's scheduled for release in a couple of months time, but it'll be a while after that before it is in Ubuntu's repository.
Panda Jim's "Ubuntu Handbook" repository usually has builds available soon after release (https://launchpad.net/~ubuntuhandbook1/ ... u/audacity)
waxcylinder
Post by waxcylinder » Sat Jul 14, 2018 10:25 am
Ah, but since this user also has a Windows machine they will be able to update that platform to 2.3.0 as soon as it is released. :)
Current target release date for 2.3.0 is 31st August
rlearning
Post by rlearning » Sun Jul 15, 2018 3:25 pm
Thanks again for all the update info.
Just to briefly fill you in, I did not originally see Steve's post about EasyTag, and I loaded it and sent a test file to the radio station and he said that it worked great. So even if I have to temporarily implement one more step, I appreciate all of the help and also knowing it will soon be fixed for anyone else who may have run into this as well.
