Detected 497 missing audio data (.au) files
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by aamediastudios » Wed Apr 18, 2018 12:21 pm
Can someone please help? I'm completely unsure where to go from here.Here are some of the log details:
Code: Select all
13:06:07: Audacity 2.2.1
13:06:07: Trying to load FFmpeg libraries...
13:06:07: Trying to load FFmpeg libraries from default path, '/Library/Application Support/audacity/libs/libavformat.55.dylib'.
13:06:07: Checking for monolithic avformat from '/Library/Application Support/audacity/libs/libavformat.55.dylib'.
13:06:07: Error: dlopen(/Library/Application Support/audacity/libs/libavformat.55.dylib, 1): image not found
13:06:07: Loading avutil from ''.
13:06:07: Error: dlopen(.bundle, 1): image not found
13:06:07: Loading avcodec from ''.
13:06:07: Loading avformat from '/Library/Application Support/audacity/libs/libavformat.55.dylib'.
13:06:07: Error: Failed to load FFmpeg libraries.
13:06:07: Trying to load FFmpeg libraries from legacy path, '/usr/local/lib/audacity/libavformat.55.dylib'.
13:06:07: Checking for monolithic avformat from '/usr/local/lib/audacity/libavformat.55.dylib'.
13:06:07: Error: dlopen(/usr/local/lib/audacity/libavformat.55.dylib, 1): image not found
13:06:07: Loading avformat from '/usr/local/lib/audacity/libavformat.55.dylib'.
13:06:07: Trying to load FFmpeg libraries from system paths. File name is 'libavformat.55.dylib'.
13:06:07: Checking for monolithic avformat from 'libavformat.55.dylib'.
13:06:07: Error: dlopen(libavformat.55.dylib, 1): image not found
13:06:07: Loading avformat from 'libavformat.55.dylib'.
13:06:07: Error: Failed to find compatible FFmpeg libraries.
13:06:13: Error: can't open file '/Users/andrewdalhouse/Dropbox/Football Debate Room/podcasts/6/FDR6_data/e00/d03/e000356c.au' (error 2: No such file or directory)
Reason: code tags added
aamediastudios
Re: Detected 497 missing audio data (.au) files
Permanent link to this post Posted by kozikowski » Wed Apr 18, 2018 1:37 pm
Which three-number Audacity version are you using?
Audacity > About...
Permanent link to this post Posted by aamediastudios » Wed Apr 18, 2018 1:52 pm
2.2.1
aamediastudios
Permanent link to this post Posted by billw58 » Wed Apr 18, 2018 3:33 pm
Audacity requires that the .aup file (for example, MyProject.aup) and the associated data folder (for example, MyProject_data) be in the same folder/directory.
From the log message it looks like the folder "FDR6_data" has been moved, or the file "FDR6.aup" has been moved. Get those two items (the file and the folder) together in the same folder and you may be able to recover your project.
Also, please read this page in the manual.
-- Bill
billw58
Permanent link to this post Posted by kozikowski » Wed Apr 18, 2018 5:27 pm
Audacity 2.2.1 can create a damaged project if you already had a Project and you wrote over it with Save As: instead of Save:.
That's why Audacity 2.2.2 was posted.
https://www.audacityteam.org/download/mac/
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 4 guests
