Template for effects
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by johnro43 » Mon Apr 16, 2018 7:45 pm
OS: Mac 10.13.3 Downloaded and installed Audacity 2.1.2, but have mostly worked with 2.1.1.
I am recording a book, which requires one file per chapter ... 40+ files. I want to use some effects ... bit of compression, etc. ... but need to have the effect be the same for each chapter. I know I can replicate settings anew for each chapter ... but is there a way to set up a template so that all will be the same?
johnro43
Re: Template for effects
Permanent link to this post Posted by steve » Mon Apr 16, 2018 8:02 pm
The current version of Audacity is 2.2.2, which is available here: https://www.audacityteam.org/download/
You can set up a "Chain" of effects, but be aware that for best results it is usually best to tweak each effect for the specific recording that you are processing. There's no getting away from the fact that producing high quality finished work is a lot of work, and short cuts usually compromise quality.
For information about Chains, see: http://manual.audacityteam.org/man/chai ... ation.html
Permanent link to this post Posted by johnro43 » Mon Apr 16, 2018 9:44 pm
Thanks for a quick and clear answer!
johnro43
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 6 guests
