Creating Keyboard Shortcuts
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
NilaJean
Post by NilaJean » Mon Mar 12, 2018 7:17 pm
Koz, the only shortcuts I know are Cmd-A, Cmd-Z, and Cmd-R (repeat effect), but am wondering if i can create a macro of RMS Normalize and Limiter with a keyboard shortcut, and one for Noise Reduction??? How about CMD + for zoom, and CMD - for zoom out?
NilaB
billw58
Re: Creating Keyboard Shortcuts
Post by billw58 » Mon Mar 12, 2018 7:26 pm
All keyboard shortcuts are documented on this manual page, or you can see them when you pull down the menus.
You can customize keyboard shortcuts in Keyboard Preferences.
You can create a macro using Audacity's Chains feature.
-- Bill
