Latency correction now under Devices
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by andrew_songs » Sat Mar 10, 2018 7:12 pm
Good news, found what I was looking for, which is now on the Devices tab.
Don't understand the logic of placing it there instead of the Recording tab,
but very happy that the adjustment remains! Thanks!
andrew_songs
Re: Latency correction now under Devices
Permanent link to this post Posted by steve » Sat Mar 10, 2018 7:22 pm
andrew_songs wrote:Don't understand the logic of placing it there instead of the Recording tab,
I agree that it was easier to find in the Recording section, but the logic of placing it in the Devices section is that the setting is specific to the selected device. If you switch to a different device, you will probably have to adjust the latency correction setting.
The settings in the "Recording" tab are independent of which device is selected.
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 7 guests
