Select Option Not working
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by brbelloni » Fri Mar 09, 2018 1:41 am
When I try and select a portion of the recording, the cursor only clicks in certain spots. For instance, if I try and select from the very end of my recording to silence from there to the end of the track, it will not allow me click exactly where I put my cursor. It is about a centimeter off. How do I fix this?
brbelloni
Re: Select Option Not working
Permanent link to this post Posted by billw58 » Fri Mar 09, 2018 2:10 am
Turn off "Snap to" in the Selection Toolbar.
-- Bill
billw58
Return to Mac OS X
Who is online
Users browsing this forum: Bing [Bot], rovf and 5 guests
