downloading Lame Library
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by SLR » Wed Mar 07, 2018 6:25 am
I am using Yosemite. Just downloaded Audacity 2.2.2 & think I'll like it. Used to use Amadeus Pro on my Mac. Similar thinking.
Dowloaded & tried to open Lame Library to export to Mp3. Will want both export libraries.
Text box says: "Lame Library v3.99,5 for Audacity.pkg can't be opened because it is from an unidentified developer.
Your Security preferences allow installation of only apps from the Mac App Store and identified developers."
Looked through Firefox & Safari preferences; nothing says the above. Where ever it came from, how do I undo this?
Thanks muchly
Susan
SLR
Operating System: OS X 10.10 Yosemite
Re: downloading Lame Library
Permanent link to this post Posted by billw58 » Wed Mar 07, 2018 5:20 pm
Right-click on the LAME installer PKG file. A context menu appears. The first item is "Open": select that. In the subsequent dialog that appears, click "Open".
-- Bill
billw58
Permanent link to this post Posted by SLR » Wed Mar 07, 2018 8:07 pm
Thank you! Thank you!
That was enough information that I was able to install the library. Bit convoluted.
SLR
Return to Mac OS X
Who is online
Users browsing this forum: Bing [Bot], rovf and 5 guests
