Choppy recording
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Choppy recording
Permanent link to this post Posted by paneergurung » Thu Mar 01, 2018 3:16 am
(I'm very sorry if this has already been addressed, but I've been searching on these boards and on Google for the past several hours and couldn't find an answer, any help is appreciated)
The program didn't used to do this, but now every recording sounds like this: https://www.dropbox.com/s/afko3097a4pwj19/Helppp.mp3?dl=0. I remember fixing this once over a year ago, but now I can't remember how I did it. Help?
paneergurung
Re: Choppy recording
Permanent link to this post Posted by kozikowski » Thu Mar 01, 2018 4:52 am
It's rough to critically analyze a performance through the haze of MP3 distortion. Post another test a little longer and WAV (Microsoft) format.
There is a list of usual suspects, Captain Renault.
What else is running on your machine? If we assume that's your voice, how is it getting into the Mac? When was the last time you shut down, went to make coffee and started it up again? I'm not after "restart" here.
Where is the work being stored? Are you using iCloud (or similar) for any of it?
The motorboating doesn't ring a bell. I note it's always there even if you can barely hear it during the silent stretches.
Is there a game or Skype running in the background? Foreground?
What is your goal? Why are you there in front of the microphone?
If it's a USB microphone, do you always have it plugged into the same USB port?
Depending on the type of sound system, do you get the motorboating if you listen to the microphone or mixer before it gets to the Mac?
Permanent link to this post Posted by billw58 » Thu Mar 01, 2018 5:02 am
Try the steps in this FAQ in the manual.
-- Bill
billw58
Permanent link to this post Posted by paneergurung » Thu Mar 01, 2018 8:46 pm
billw58 wrote:Try the steps in this FAQ in the manual.
-- Bill
Yes, worked out perfectly. Thanks!
paneergurung
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 20 guests
