No recording on OS X 10.10.5 using quad-capture
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by lcreek » Mon Feb 26, 2018 8:20 pm
I am trying to record from a yamaha mixer board through a Roland Quad-Capture into a macbook pro running OS X 10.10.5. I have selected the quad-capture as the input device on the mac settings, as well as in audacity, but nothing is recorded. I'm running Audacity 2.2.1
I also tried a couple of other options but Audacity seems only to record when using the built-in microphone, even if the other sources were selected (e.g. headphones with microphone).
Has anyone had this issue?
thanks for any help.
lcreek
Operating System: OS X 10.10 Yosemite
Re: No recording on OS X 10.10.5 using quad-capture
Permanent link to this post Posted by steve » Thu Mar 01, 2018 10:51 am
Does the device work in other applications (such as Garage Band) ?
Permanent link to this post Posted by lcreek » Tue Mar 13, 2018 6:55 pm
yes it works in garage band fine
lcreek
Return to Mac OS X
Who is online
Users browsing this forum: rovf and 5 guests
