best way to delete breaths in track
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by KacyJ01 » Thu Feb 22, 2018 9:33 pm
Using Audacity 2.1.1 on MAC OS High Sierra 10.13.3
General question - I just cut out the breath sounds on recording using the edit tool is there a better way to do this? I sometimes cannot select the entire breath sound. Should I use Noise Reduction effect if you can capture the whole thing?
Thanks for your advice
KacyJ01
Re: best way to delete breaths in track
Permanent link to this post Posted by Trebor » Thu Feb 22, 2018 10:36 pm
KacyJ01 wrote: I just cut out the breath sounds on recording using the edit tool is there a better way to do this?
There are de-breath plugins which reduce/remove all breath sounds in one pass. They are noise gates.
KacyJ01 wrote: Should I use Noise Reduction effect ...
Definitely not for de-breath.
Trebor
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 5 guests
