Is the latest version of iTunes compatible w/ Audacity 2.1.2
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by mezzopiano » Mon Feb 19, 2018 2:30 am
I am trying to import audio into Audacity while iTunes is open, and my music will not populate. I have not had this issue in the past. Any ideas?
mezzopiano
Re: Is the latest version of iTunes compatible w/ Audacity 2
Permanent link to this post Posted by kozikowski » Mon Feb 19, 2018 2:44 am
You're dragging from iTunes onto the desktop and then into Audacity, right?
If you're trying to go direct, you may need to install the FFMpeg format translation software.
https://www.audacityteam.org/download/mac/
Scroll down.
Depending on how you did it, your iTunes music is in Apple AAC format. I don't think Audacity can handle that without help.
[time passes]
My music imported as M4A. I don't think Audacity will do that without FFMpeg.
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 10 guests
