Splitting multiple stereo into mono at once
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by nicsnics » Fri Feb 16, 2018 3:18 pm
Hi everyone,
I'm working on a drum sound database, all the sounds are stereo but it's basically 2 same monos, and i need mono files for my drum sampler, I'm now splitting each track stereo to mono and deleting one side, track by track. Is there a way to select all tracks and split them all together?
This is possible but I don't want to mix but split :)
Many thanks if someone has the answer.
Nics
nicsnics
Operating System: OS X 10.10 Yosemite
Re: Splitting multiple stereo into mono at once
Permanent link to this post Posted by steve » Fri Feb 16, 2018 3:27 pm
nicsnics wrote: Is there a way to select all tracks and split them all together?
Not yet.
Permanent link to this post Posted by nicsnics » Fri Feb 16, 2018 3:29 pm
Ok, thanks your reply :D
nicsnics
Return to Mac OS X
Who is online
Users browsing this forum: Google [Bot] and 3 guests
