Trouble with editing problematic recordings
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by JamesRPVee » Fri Feb 16, 2018 12:24 am
Audio Extract.wav
Extracted audio file from problem recording
(1.13 MiB) Downloaded 8 times
Hello. I'm a volunteer for a small non-profit organization, using Audacity to edit audio files of lectures our organization presents to the public on a regular schedule.
I need some assistance with a technical issue we've been having with some of our recent recordings. The problem originates during the recording process, but I'm left with trying to figure out how to improve the sound quality as best I can.
If anyone has any idea of how I can improve on the sound quality of these recordings, I'd very much appreciate hearing from you.
I've attached a short WAV clip from one of these recordings, to give you a better idea of what I'm talking about.
Thanks so much for any help you may be able to provide me with.
JamesRPVee
Re: Trouble with editing problematic recordings
Permanent link to this post Posted by Trebor » Fri Feb 16, 2018 2:25 am
JamesRPVee wrote: Audio Extract.wav Extracted audio file from problem recording (1.13 MiB)
Cutting the bass frequencies helps a little ...
cut bass equalization.png (25.76 KiB) Viewed 165 times
https://manual.audacityteam.org/man/equalization.html
But there's no way of reversing the overload distortion.
Trebor
Permanent link to this post Posted by JamesRPVee » Fri Feb 16, 2018 2:40 am
Thanks so much for your help. I was guessing that the overloading on the recording might be permanent, but thought I'd ask anyway. I'll give your recommendation a try though.
JamesRPVee
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 4 guests
