Nyquist Plug-ins not generating in audacity 2.2.1
Help for Audacity on macOS.
machacee
Post by machacee » Thu Feb 15, 2018 7:20 pm
I am at a complete loss. I have been trying load ACX check, along with others.
* I have downloaded and dropped into the proper plugin file. (~/Library/Application Support/audacity/Plug-Ins_
*I have renamed to NOT have txt. extensions
* Add/Remove still won't populate added plugins.
* I have made sure I have the current version of Audacity.
* I have shut off program and computer, hoping a reload would populate plug-ins.
--I was able to get this (audacity 2.2.1) to work on a 10.9.5 mac with no problems, and not renaming files.
--MUST find a way to get to work with my 10.13.3 mac.
--I am not the only one having this problem.
Any and all help would be greatly appreciated!
E
billw58
Re: Nyquist Plug-ins not generating in audacity 2.2.1
Post by billw58 » Fri Feb 16, 2018 10:18 pm
You seem to be doing everything right, so this is a mystery.
Could you post a screen shot of your audacity/Plug-Ins folder? Also a screen shot of the Plug-in Manager dialog?
-- Bill
hwemar
Post by hwemar » Sat Feb 17, 2018 7:20 pm
Audacity 2.2.1, MacOS 10.13.3
I'm having the same problem and have attached the requested screenshots for billw58
I have enabled the file under both Effect and Analyze managers. They seem to Enable but Acx-check does not show on the list under Analyze. I go back and look at the listed plug-ins to see if Acx-Check is enabled and it is again listed as New. It appears the Enable is not working.
Screen Shot 2018-02-17 at 12.11.45 PM.png (68.73 KiB) Viewed 339 times
Screen Shot 2018-02-17 at 12.17.22 PM.png (176.84 KiB) Viewed 339 times
Reason: Place images inline to preserve board layout
hwemar
Post by hwemar » Sat Feb 17, 2018 7:32 pm
I got the attached file from another post about the same thing. It appears that using Safari to download the Acx-check.ny file changes it to a Act-Check.ny.txt file and despite removing the .txt from it...the Enable of that file fails. I found another Acx-check.ny file from Forum Staffer kozikowski and that one works, Enables.
Acx-check.ny
(9.33 KiB) Downloaded 78 times
billw58
Post by billw58 » Sat Feb 17, 2018 10:22 pm
Glad you got it sorted out.
If you look at the first screen shot of your Plug-Ins folder, you'll see that the file for ACX-check.ny is an alias. That was the source of the problem.
-- Bill
