Recording from Itunes
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by claymoreinn » Thu Feb 15, 2018 3:13 am
I am trying to record an audio book file from iTunes. The file is very long so I don't want to listen to it while it is recording. When I turn down the volume on my macbook pro it also turns the recording level down. Is there a way to mute the sound but still record from itunes?
claymoreinn
Re: Recording from Itunes
Permanent link to this post Posted by cyrano » Thu Feb 15, 2018 10:48 pm
Plug in a headphone jack?
I'm not sure why you'd want to re-record a file that is already digital and on your computer. No way to export from iTunes because of DRM, perhaps?
cyrano
Permanent link to this post Posted by claymoreinn » Fri Feb 16, 2018 9:12 pm
cyrano wrote:Plug in a headphone jack?
Exactly. I tried the headphone jack but it didn't work.
claymoreinn
Permanent link to this post Posted by billw58 » Fri Feb 16, 2018 10:16 pm
How are you recording the file? Soundflower? iShowU Audio Capture?
Why not set it up to record overnight? You could use Audacity's timer record function.
-- Bill
billw58
Permanent link to this post Posted by claymoreinn » Mon Feb 19, 2018 10:04 pm
billw58 wrote:How are you recording the file? Soundflower? iShowU Audio Capture?
-- Bill
Bill, thanks for this question. It made me look into this because I didn't have any recording input/output set up. Once I installed Soundflower, it gave me an opportunity to select this as in input and output, so I was able to record this properly. Problem solved. Thank you again!
claymoreinn
Return to Mac OS X
Who is online
Users browsing this forum: Bing [Bot] and 5 guests
