Audacity 2.2.1 and Saffire 6 USB
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by peter_wicks » Tue Feb 13, 2018 12:37 pm
I am using MacOS 10.13.3 and have connected a Focusrite Saffire 6 USB. I am trying to record from Vinyl and I get very distorted sound. I have downloaded the proper software for the Saffire from the Focusrite website. I used to use a windows 7 machine which worked fine.
peter_wicks
Re: Audacity 2.2.1 and Saffire 6 USB
Permanent link to this post Posted by peter_wicks » Thu Feb 15, 2018 9:18 am
peter_wicks wrote:I am using MacOS 10.13.3 and have connected a Focusrite Saffire 6 USB. I am trying to record from Vinyl and I get very distorted sound. I have downloaded the proper software for the Saffire from the Focusrite website. I used to use a windows 7 machine which worked fine.
I think I am getting stuttering on my recordings.
peter_wicks
Permanent link to this post Posted by billw58 » Thu Feb 15, 2018 4:52 pm
Try these suggestions and see if anything helps.
-- Bill
billw58
Permanent link to this post Posted by peter_wicks » Sat Feb 17, 2018 12:59 pm
Thank you Bill. I have tried these options and nothing has changed.
In fact, I have now bought the albums, (from iTunes) that I was trying to record.
Frustrating as I was really impressed with Audacity when I used it on a windows machine.
Thanks again.
peter_wicks
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 3 guests
