I'm brand new to Audacity...and I need help
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by pete12 » Sun Feb 11, 2018 8:20 pm
I'm using Audacity 2.2.1. "Record" only works when I select "built-in mic." If I select "M-box mini" mic, it will not record (by the way, I always plug-in my mic before opening Audacity). Also, when I DO record with "built-in" mic, then edit out a segment, hit rewind, then play, it just freezes. It will not play. Lastly, I get the spinning wheel, quite a bit on my iMac. What am I doing wrong? Help.
pete12
Re: I'm brand new to Audacity...and I need help
Permanent link to this post Posted by billw58 » Mon Feb 12, 2018 7:56 pm
What version of Mac OS are you using, and what Mac model?
-- Bill
billw58
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 3 guests
