Audacity 2.2.1 Empty dialogs
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by sburlot » Thu Feb 08, 2018 12:06 am
On MacOS 10.13.3, with Audacity 2.2.1, if I choose "Open", a completely black dialog appears
When I choose Export (any format), a system gray dialog appears, but no contents.
I can close both dialogs by pressing the Esc key.
All other dialogs are fine.
I can open a file by dragging it to Audacity, but these 2 options are not usable.
I tried to reinstall Audacity, deleting ~/Library/Application Support/audacity, but it still doesnt work.
What can I try to solve this?
Thanks,
Stephan
PS: strange: in the screenshot I made of the Open Dialog, it appear empty, but not black
Open Dialog
Screen Shot 2018-02-08 at 01.01.15.png (52.34 KiB) Viewed 161 times
Export Dialog
Screen Shot 2018-02-08 at 01.01.33.png (59.37 KiB) Viewed 161 times
sburlot
Re: Audacity 2.2.1 Empty dialogs
Permanent link to this post Posted by sburlot » Thu Feb 08, 2018 12:28 am
Well, a reboot fixed it.
Weird.
sburlot
Permanent link to this post Posted by billw58 » Thu Feb 08, 2018 3:49 pm
sburlot wrote:Well, a reboot fixed it.
Weird.
Indeed.
-- Bill
billw58
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 3 guests
