Another instance of Audacity running error
Help for Audacity on macOS.
jaxhere2
Post by jaxhere2 » Fri Jan 19, 2018 5:23 pm
I've been running audacity for a long time on a Macbook pro using High Sierra without problems but today, after downloading some system upgrades, I can't run Audacity. I get a window popping up which says there is another instance already running and that I should use it to open files. BUT there is no other version running.
Even after I Force Quit what shows in the system monitor, then restart Audacity, this message reappears, and again there is an icon showing it running in the system monitor. I force quit that, try to restart and the same thing occurs. How do I get this up and running again?
billw58
Re: Another instance of Audacity running error
Post by billw58 » Fri Jan 19, 2018 5:46 pm
Have you tried restarting the Mac?
If that doesn't work, go to ~/Library/Application Support/audacity and trash the contents of the "SessionData" folder.
-- Bill
jaxhere2
Post by jaxhere2 » Fri Jan 19, 2018 5:52 pm
Thanks Bill. Restarting didn/t work and I even reinstalled Audacity without any improvement, but erasing the contents of the session contents folder did the trick.
