installation on High Sierra from source
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Contact:
Re: installation on High Sierra from source
Post by steve » Tue Jan 09, 2018 6:39 pm
baj wrote:** INSTALL SUCCEEDED **
Hooray and congratulations :D
baj wrote:If by chance you have a concrete example script that I can use to start developing my use-case that would be even better... ;)
Sorry, no I don't.
baj
Post by baj » Wed Jan 10, 2018 5:24 pm
the good news: Audacity works, I installed the program from the /tmp folder and it looks nice.
the bad new: the scripting module won't compile :o :roll:
I found that the make file refers to SDKs/MacOSX10.4u.sdk so I found it on some github page and copied it to the SDK folder like before.
I also changed the version to 10.6 and 10.12.
All of them are complaining about wx/wx.h and then setup.h not being found. Thus, I included the -I directories from the installation used when creating audacity.
With the 10.12 version I get the least errors, so I post this here:
In file included from /Users/bernd/programs/wxWidgets-audacity-fixes/include/wx/nonownedwnd.h:14:
/Users/bernd/programs/wxWidgets-audacity-fixes/include/wx/window.h:1991:40: error: type 'wxAccessible' is not a
direct or virtual base of 'wxWindowAccessible'
wxWindowAccessible(wxWindow* win): wxAccessible(win) { if (win) win->SetAccessible(this); }
I don't know what I am doing anymore and have no clue where to start searching. Is it possible that this scripting module is not working on Mac (High Sierra)? At some point I saw a message that only windows OS is supported...
Thanks again for the continued support.
Contact:
Post by steve » Wed Jan 10, 2018 7:42 pm
baj wrote:Is it possible that this scripting module is not working on Mac (High Sierra)?
It's possible, but I don't really know as I've not tried. (My usual platform is Linux.)
I've asked the developers if anyone can advise.
