Clicking or crackling sound in audio recording
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
amyleo
Post by amyleo » Sun Jan 07, 2018 6:13 pm
Hello,
I am recording a podcast and cannot determine the source of a clicking or crackling sound. I've attached an example. Does anyone know what this is called, and/or how to prevent it?
Part of the challenge is that it is difficult to recreate because it often happens over an hour into recording. I get started and think I'm good to go, and then listen later and notice it started happening again. This leads me to believe it could be related to latency, but I can't recreate it by opening all of the applications on my computer, dozens of web browser tabs, etc. I'm recording at 16-bit PCM and Mono, 44100 Hz, industry standard for podcasts.
Here are the details of my setup:
- Shure SM58 microphones
- Focusrite Scarlett 18i8 Preamp
But, this also happens with by Yeti Blue Microphone, so I don't think it has to do with the microphone.
I'm using a brand new USB cord and tried jostling it to see if its a connection issue. Doesn't seem to be.
Any ideas? Please help!
Example of Clicking.mp3
Here's an example of the clicking or crackling sound
(383.67 KiB) Downloaded 25 times
Jasta204
Re: Clicking or crackling sound in audio recording
Post by Jasta204 » Sun Jan 07, 2018 9:40 pm
I'm new to Audacity and am experiencing the same issue as Amyleo - attaching a sample as well. (Amyleo - I wish I could be of assistance!).
Here's my setup
mics: 2 Shure S58's
mixer: Yamaha MG10XU
(connected to Macbook Pro via USB, running OS 10.11.6)
headphone amp: Pyle PHA40
headphones: 2 AT20x's, 1 Bayerdynamic DT770
I've been Google-ing for the past two days and can't find a solid ID of the issue or how to fix and prevent it. Any assistance would be *most* appreciated!
audactiy_clicking_sample.mp3
(131.72 KiB) Downloaded 18 times
billw58
Post by billw58 » Mon Jan 08, 2018 3:34 am
Try the recommendations on this page in the manual and let us know if they help.
-- Bill
amyleo
Post by amyleo » Wed Jan 10, 2018 8:27 pm
Thank you, I've tried all of these things, except for antipop, and they are not helping. The issue is still present. Any other suggestions?
