How to fix .WAV file, 72MB, no duration
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
LFL
Post by LFL » Thu Dec 14, 2017 10:31 am
Version of OS X: Sierra
Version of Audacity: Audacity 2.1.3
.dmg installer
Hi everyone,
I have a .WAV file that says it's 72MB but doesn't state the duration. It doesn't play in VLC, and the Codec details come up blank. When I import the raw data to Audacity, it's mainly white noise, but you can hear some very quiet, high-pitched but incomprehensible sounds that might be voices.
Does anyone have any ideas as to how to fix this file?
Thanks in advance!
All the best,
Ali
Contact:
Re: How to fix .WAV file, 72MB, no duration
Post by steve » Thu Dec 14, 2017 11:53 am
My guess is that either it's not really a WAV file, or it is corrupted beyond repair.
Where did the file come from?
LFL
Post by LFL » Thu Dec 14, 2017 11:59 am
steve wrote:My guess is that either it's not really a WAV file, or it is corrupted beyond repair.
Under info it says it's Waveform audio, but yeah, maybe it is corrupted beyond repair... :cry:
The file is from a handheld mic/recording device that has been working pretty reliably -- we've made over 50 recordings on it so far, all of them WAV files that have worked in both VLC and Audacity.
Contact:
Post by steve » Thu Dec 14, 2017 12:31 pm
How do you transfer the WAV files from the recorder to your Mac?
If you make a new recording on the device, does that work?
How much space is left on the recorder?
LFL
Post by LFL » Thu Dec 14, 2017 12:47 pm
steve wrote:How do you transfer the WAV files from the recorder to your Mac?
We transfer the WAV files from the recorder through a USB cord.
New recordings work fine.
There's still plenty of space left on the recorder.
Contact:
Post by steve » Thu Dec 14, 2017 1:00 pm
LFL wrote:We transfer the WAV files from the recorder through a USB cord.
You could try deleting the file from your computer and then transferring it again, just in case it became corrupted during the transfer.
Does the file play on the recorder?
If that doesn't work, then I suspect the recording may not be salvageable.
LFL
Post by LFL » Thu Dec 14, 2017 1:47 pm
Hmm, we transferred it again and it didn't work, and we tried playing it on the recorder and it said there was an error.
We're hypothesising it might be to do with PCM/LP? (I don't know anything about this!) All the recordings are labeled both PCM + LP or just PCM, but this corrupted file was only labeled LP.
Anyway, thanks so much for your help! We're going to arrange the interview again and record it again, with a phone recording as a back up this time!
