can't recognise file after exporting wav with Reaper
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by lucadanieli » Sun Dec 10, 2017 2:10 pm
Hello,
as I love the stretching algorithm of audacity, I want to use it with my sound files.
However, I tried to export a sound file with reaper with this specification:
Sample rate: 44100
Channels: mono
Resample mode: Extreme HQ
WAV bit: 24 PCM
Large files (mine is 1 GB): Auto WAV/Wave64
The file is streamed by the QuickTime player, but can't be opened by Audacity because the file type is not recognised.
Does anybody know why?
Best
Luca
lucadanieli
Re: can't recognise file after exporting wav with Reaper
Permanent link to this post Posted by kozikowski » Sun Dec 10, 2017 4:08 pm
That's a little odd because I thought Audacity automatically used QuickTime Services.
Do you have FFMpeg installed (scroll down)?
http://www.audacityteam.org/download/mac/
Return to Mac OS X
Who is online
Users browsing this forum: Google [Bot] and 4 guests
