multi-track recording
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by patnich » Fri Sep 08, 2017 10:05 pm
How do I do that?
Can you provide the url of the links in the manual that covers this topic?
macos 10.12.6 audacity 2.0.6
thx, pat
patnich
Re: multi-track recording
Permanent link to this post Posted by kozikowski » Sat Sep 09, 2017 1:36 am
Sure. Anyone can do plain overdubbing as long as your computer is up to perfect playback and perfect recording at the same time. Any machine that's struggling to do either of those by itself may not have enough horsepower for overdubbing.
There are two versions. Plain overdubbing is where you create new tracks against existing backing tracks, but you don't hear yourself while you're playing or singing. This is where you see people with one earphone slipped off so they can hear themselves.
Perfect overdubbing is where you hear a perfect theatrical mix of your live performance and the backing tracks in your headphones during the performance. That usually takes specialist hardware—such a mixing board or special microphone with Zero Latency Monitoring.
Listening to the computer will almost never give you perfect overdubbing.
http://manual.audacityteam.org/man/tuto ... rdubs.html
The manual takes you through making a plain, ordinary sound recording before you do anything else. If you have trouble doing that, the overdubbing setup will dig you a hole very rapidly.
Permanent link to this post Posted by kozikowski » Sat Sep 09, 2017 1:38 am
No, I don't recommend Apple earbuds for music production. They were handy for the picture and in a pinch, they do work.
Return to Mac OS X
Who is online
Users browsing this forum: arlie and 4 guests
