Multitrack recording with Behringer Xenyx 1204 USB
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by [email protected] » Sun Sep 03, 2017 4:43 pm
I am using 10.12.6 Mac OS Sierra and Audacity 2.1.3. I can record multiple mics into the same track using Audacity.
I want to know if its possible to do multi track recording using Xenyx 1204USB on the above versions of Mac OS & Audacity.
Thank in advance...
[email protected]
Re: Multitrack recording with Behringer Xenyx 1204 USB
Permanent link to this post Posted by cyrano » Sun Sep 03, 2017 6:49 pm
The built in USB interface in the Behringer 1204USB only allows two channels to be recorded simultaneously.
You can mix more than two mics, but the recording will only be stereo, not multi-track. Most small USB mixers are like this...
cyrano
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 6 guests
