Open With Issue -Mac Ver. 2.1.3
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by Pabco » Thu Aug 24, 2017 2:07 pm
Greetings.
I recently upgraded to version 2.1.3 Audacity for mac and am having the following minor issue. When I right-click on an .mp3 file and choose (open with) Audacity, the program opens but does not load the file (as in all previous versions I've had). I then have to choose File/Open and point to the file. It then loads the file.
Can anyone possible help me correct this minor issue? Thank you.
Pabco
Re: Open With Issue -Mac Ver. 2.1.3
Permanent link to this post Posted by billw58 » Thu Aug 24, 2017 3:28 pm
This is a known issue with Audacity 2.1.3 on Sierra. It is fixed in the upcoming 2.2.0 release which should be out within the next few weeks.
-- Bill
billw58
Permanent link to this post Posted by Pabco » Thu Aug 24, 2017 4:38 pm
Thanks for the quick reply Bill, I appreciate it.
Looking forward to the update.
Paul
Pabco
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 6 guests
