Problems setting Audacity as default file type
Help for Audacity on macOS.
rubberjohnson
Post by rubberjohnson » Thu Aug 17, 2017 9:37 am
Hi,
Just tried the upgrade to Sierra (I can downgrade if necessary!) so now using Mac OSX 10.12 and Audacity 2.1.3. I installed it from the DMG file, I think, back when I was using El Capitan.
I used to be able to assign Audacity as the default program for a certain type of file, i.e. wav or mp3. Although I can still do that, now when I double click a file it only goes as far as opening Audacity, it doesn't actually open the file within Audacity like it used to.
Does anyone know a way round this?
Cheers
billw58
Re: Problems setting Audacity as default file type
Post by billw58 » Thu Aug 17, 2017 3:49 pm
rubberjohnson wrote: I used to be able to assign Audacity as the default program for a certain type of file, i.e. wav or mp3. Although I can still do that, now when I double click a file it only goes as far as opening Audacity, it doesn't actually open the file within Audacity like it used to.
By that I assume you mean you do "Get Info" on (for example) a WAV file, then under "Open with" you choose "Audacity" then click the "Change all" button. That should work.
It works for me on El Capitan.
Let's wait for someone who's running Sierra to also test this.
-- Bill
cmac185
Post by cmac185 » Thu Aug 17, 2017 4:04 pm
Starting Audacity by double clicking on a file was broken in 2.1.3 in that Audacity didn't load the file even though it started. This has been fixed for 2.2.0 so this problem will go away when that comes out.
waxcylinder
Post by waxcylinder » Thu Aug 17, 2017 4:12 pm
I'm running macOS Sierra 10.12.6
I confirm that with Audacity 2.1.3 using the right-click > Get Info > Open with or just using right-click > Open With on the audio you do just get Audacity opening but failing to import the audio file.
However..... testing on the latest alpha nightly for Mac this appears to have been fixed.
As a workaround you should be able to drag&drop an audio file onto an already open Audacity window (doesn't work if you drag&drop onto the audacity.app icon in Finder>Applications - it should - it does work in 2.2.0 alpha test build) .
If you're feeling bold you could try the latest alpha nightly: https://www.fosshub.com/Audacity-Mac-Nightlies.html
If you're feeling only slightly bold - were are hoping to soon produce a beta test to let out into the wild (hopefully in the next few days)
P.S. thanks to testing this I've learnt how to avoid having my MP3/AAC/WAV files default opening in iTunes - a good steer, thanks 8-) :geek:
rubberjohnson
Post by rubberjohnson » Thu Aug 17, 2017 8:06 pm
Thanks all! I'll wait until 2.2 comes out,then.
Yeah, I was also sick of accidentally opening iTunes, or having to 'right-click, open with...' when opening a wav file, so changing the default action is a helpful thing to have.
Cheers
