Some sort of echo in recordings. How to eliminate?
Help for Audacity on macOS.
photoshooter
Post by photoshooter » Mon Jul 17, 2017 9:57 pm
Hello. I have been trying to record some interviews online, in different websites, mostly for educational purposes ( including interviews that I have done myself) using current and previous versions of Audacity, and current and previous OSX.
Currently I am in OS X Sierra and Audacity 2.1.3, and the "RANDOM" event of echo popping out in some recordings is becoming more annoying and more frequent.
At some point I thought it was a matter of high volume applied to the recording , and I lowered there volume, all to no avail. I have not tried to apply any sound effects ( so no echo on purpose) and the defect keeps showing up in varying degrees.
Very old previous versions of Audacity never gave me this glitch. Now I got a brand new 2017 iMac as my main desktop, so I can not go back to some of the previous versions, and I would not like to do it anyways. I rather have this sorted out!
So, in brief, has anyone found this issue, and if so, has anyone found a solution? Is there some setting I am doing wrong here? The Manual and the FAQ's do not mention this. And BTW, it has also happened with Skype.
Thanks in advance!
Re: Some sort of echo in recordings. How to eliminate?
Post by kozikowski » Tue Jul 18, 2017 12:03 am
And that's the first alarm bell right there. You can't easily record Skype on a Mac (or any machine) and you can't easily record on-line content on a Mac.
So how are you doing that? What's the setup or software?
photoshooter
Post by photoshooter » Tue Jul 18, 2017 12:16 am
Koz, I do not follow.... I am using Audacity 2.1.3 on Mac OS X Sierra. I am using SoundFlower ( 2 Channels) as my Device, and both Input Recording volume and Output volume set at 80%. All other stuff is set by the app, meaning, there is little else to modify.
On many occasions, I was able to get perfect sound recordings, years go, even from Skype! That is the magic of Audacity.
Now I am getting echo in similar recordings. Any suggestion?
THX!
photoshooter
Post by photoshooter » Tue Jul 18, 2017 12:39 am
Many thanks but I already sorted it out!
It turned that there was a more recent version of LAME that I just installed, and it is all sorted out. I am back to my good quality recordings.
Thanks!!
